Test 4 of uArm
IMG_0126
A Vacuum Gripper Suction Cup is often used on industry robot arm in manufacture. And we also add a small one on uArm.
IMG_0060 IMG_0061
The Vacuum Gripper Suction Cup is controlled by a small Vacuum Pump and a Solenoid Valve.
Vacuum Pump
We made the first load test of the robot arm by using the Vacuum Gripper Suction Cup. It can lift a 330ml Coca Cola and move it to another place. More applications and test videos with the Vacuum Gripper Suction Cup will be updated soon.
You may also like...
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
